はじめに
This guide will show you how to properly remove and replace the left or right speaker of your Dell XPS 18.
必要な工具と部品
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
Disconnect the volume control cable and pull it back.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
