はじめに
This guide will show you how to replace the battery for your Dell XPS 18 if it has failed.
必要な工具と部品
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
It’s not necessary to remove the cables. Unclip the white touch cable from the touch board as shown in step 8, then remove the two screws holding the board to the frame, as shown in step 9. The board can then be moved out of the way to lay flat on your work surface without having to disconnect all the cables. Doing this eliminates this step and step 5. The order of operations then would be steps 1-3, 8, 9, 6, 7, and 10.
Disconnect the black camera cable and pull it back to prevent future hassle.
Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
Use the plastic opening tool's angled edge to pry the black battery cable loose.
Remove the battery.
13 の人々がこのガイドを完成させました。
9 件のコメント
needs the help to repair the Dell XPS18
It all worked good. Thanks.
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
I did this and now my comp just has a double blinking white light…? and will not turn on.
Mine too, did you manage to find what it was?
Wow! I cannot believe how straight forward this guide is!!! Photos depicting every step. My computer now says “1 hour and 12 min until full charge"!!!! Thank you very much!!!!!
I replaced the battery and still having the same problem. Please help
Chris Nick - 返信
