必要な工具と部品
Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
Close the display, and flip the laptop over so that the bottom faces upwards.
Remove the two 16 mm screws with a Phillips screwdriver.
Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
Gently flip the laptop with its bottom facing you.
Remove the four 8mm screws with a Phillips screwdriver.
Remove the two 16mm battery casing screws with a Phillips screwdriver.
Remove the two 16mm corner screws with a Phillips screwdriver.
Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
3 の人々がこのガイドを完成させました。
