メインコンテンツにスキップ
Dell XPS 17 L702X Keyboard Replacement
必要な工具と部品
  1. Dell XPS 17 L702X Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Keyboard Replacement: 手順 2、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 2、 2の画像 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Keyboard Replacement: 手順 3、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 3、 2の画像 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Keyboard Replacement, Hard Drive: 手順 4、 1の画像 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Keyboard Replacement: 手順 5、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 5、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 5、 3の画像 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Keyboard Replacement: 手順 6、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 6、 2の画像 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Keyboard Replacement: 手順 7、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 7、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 7、 3の画像 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Keyboard Replacement: 手順 8、 1の画像 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Keyboard Replacement: 手順 9、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 9、 2の画像 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Keyboard Replacement: 手順 10、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 10、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 10、 3の画像 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Keyboard Replacement: 手順 11、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 11、 2の画像 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Keyboard Replacement: 手順 12、 1の画像 1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Keyboard Replacement, Palm Rest: 手順 13、 1の画像 1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Keyboard Replacement: 手順 14、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 14、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 14、 3の画像 3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Keyboard Replacement: 手順 15、 1の画像 1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Keyboard Replacement: 手順 16、 1の画像 1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Keyboard Replacement: 手順 17、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 17、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 17、 3の画像 3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Keyboard Replacement: 手順 18、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 18、 2の画像 2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Keyboard Replacement: 手順 19、 2の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 19、 2の画像 2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Keyboard Replacement: 手順 20、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 20、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 20、 3の画像 3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Keyboard Replacement: 手順 21、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 21、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 21、 3の画像 3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Keyboard Replacement: 手順 22、 1の画像 1
    • Remove the palm rest from the laptop.
  23. Dell XPS 17 L702X Keyboard Replacement, Keyboard: 手順 23、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement, Keyboard: 手順 23、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement, Keyboard: 手順 23、 3の画像 3
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Dell XPS 17 L702X Keyboard Replacement: 手順 24、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 24、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 24、 3の画像 3
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Dell XPS 17 L702X Keyboard Replacement: 手順 25、 3の画像 1 Dell XPS 17 L702X Keyboard Replacement: 手順 25、 3の画像 2 Dell XPS 17 L702X Keyboard Replacement: 手順 25、 3の画像 3
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Dell XPS 17 L702X Keyboard Replacement: 手順 26、 1の画像 1
    • Remove the keyboard from the laptop.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Monica Oropeza
メンバー登録日: 09/17/15
381 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S2G6
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 23
今までの合計 2,853
