メインコンテンツにスキップ
Dell XPS 15 9570 Keyboard Replacement
必要な工具と部品
  1. Dell XPS 15 9570 Keyboard Replacement, Base Cover: 手順 1、 1の画像 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 2、 3の画像 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Keyboard Replacement: 手順 3、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 3、 2の画像 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Keyboard Replacement: 手順 4、 1の画像 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Keyboard Replacement, Battery: 手順 5、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Keyboard Replacement: 手順 6、 1の画像 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Keyboard Replacement: 手順 7、 1の画像 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Keyboard Replacement, Heat Sink: 手順 8、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Heat Sink: 手順 8、 2の画像 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Keyboard Replacement: 手順 9、 1の画像 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Keyboard Replacement, Fan: 手順 10、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Fan: 手順 10、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Keyboard Replacement: 手順 11、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Keyboard Replacement: 手順 12、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 12、 2の画像 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Keyboard Replacement: 手順 13、 1の画像 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Keyboard Replacement, RAM: 手順 14、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, RAM: 手順 14、 2の画像 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Keyboard Replacement: 手順 15、 1の画像 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Keyboard Replacement, SSD: 手順 16、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, SSD: 手順 16、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Keyboard Replacement: 手順 17、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 17、 2の画像 2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Keyboard Replacement, Wireless Card: 手順 18、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Wireless Card: 手順 18、 2の画像 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Keyboard Replacement: 手順 19、 1の画像 1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Keyboard Replacement: 手順 20、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 20、 2の画像 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Keyboard Replacement: 手順 21、 1の画像 1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Keyboard Replacement, Keyboard: 手順 22、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement, Keyboard: 手順 22、 2の画像 2
    • Disconnect the two motherboard cables using the opening tool.
  23. Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 23、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 24、 3の画像 3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Keyboard Replacement: 手順 25、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 25、 2の画像 2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  26. Dell XPS 15 9570 Keyboard Replacement: 手順 26、 2の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 26、 2の画像 2
    • Disconnect the keyboard cables, labeled BL and KB, using the opening tool.
  27. Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 1 Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 2 Dell XPS 15 9570 Keyboard Replacement: 手順 27、 3の画像 3
    • Unscrew the 1.9mm screws using a Phillips #00 screwdriver.
    • Flip the cutouts on the keyboard to reveal and unscrew remaining 1.9mm screws underneath.
    • Remove the keyboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sophie
メンバー登録日: 11/09/23
301 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 3-1, Harley Fall 2023 IUPUI, Team 3-1, Harley Fall 2023人のメンバー
IUPUI-HARLEY-F23S3G1
4 メンバー
3のガイドは作成済み
コメント 1 件
Thanks alot.
Motherboard: 2 more cables to disconnect.
Keyboard backside some more screws to remove.
Mister Iks - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 27
過去 30 日: 95
今までの合計 1,398
