メインコンテンツにスキップ
Dell XPS 15 9560 Motherboard Replacement
必要な工具と部品
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Motherboard Replacement: 手順 2、 1の画像 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Motherboard Replacement: 手順 3、 1の画像 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Motherboard Replacement: 手順 4、 1の画像 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Motherboard Replacement, Battery: 手順 5、 1の画像 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the battery.
  8. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: 手順 8、 1の画像 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): 手順 10、 1の画像 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: 手順 11、 1の画像 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  12. Dell XPS 15 9560 Motherboard Replacement: 手順 12、 1の画像 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  13. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: 手順 13、 1の画像 1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  14. Dell XPS 15 9560 Motherboard Replacement: 手順 14、 1の画像 1
    • Disconnect the wireless card cables from the wireless card.
  15. Dell XPS 15 9560 Motherboard Replacement: 手順 15、 1の画像 1
    • Slide the wireless card out of its slot.
  16. Dell XPS 15 9560 Motherboard Replacement, Fans: 手順 16、 1の画像 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  17. Dell XPS 15 9560 Motherboard Replacement: 手順 17、 1の画像 1
    • Unplug the fan cable.
  18. Dell XPS 15 9560 Motherboard Replacement: 手順 18、 1の画像 1
    • Carefully remove the left-side fan.
  19. Dell XPS 15 9560 Motherboard Replacement: 手順 19、 1の画像 1
  20. Dell XPS 15 9560 Motherboard Replacement: 手順 20、 1の画像 1
    • Remove the right-side fan.
  21. Dell XPS 15 9560 Motherboard Replacement, RAM: 手順 21、 2の画像 1 Dell XPS 15 9560 Motherboard Replacement, RAM: 手順 21、 2の画像 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  22. Dell XPS 15 9560 Motherboard Replacement, Motherboard: 手順 22、 1の画像 1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  23. Dell XPS 15 9560 Motherboard Replacement: 手順 23、 1の画像 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  24. Dell XPS 15 9560 Motherboard Replacement: 手順 24、 1の画像 1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  25. Dell XPS 15 9560 Motherboard Replacement: 手順 25、 1の画像 1
    • Remove the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jada Houser
メンバー登録日: 09/28/21
839 ポイント
7のガイドは作成済み
チーム
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S4G5
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 54
今までの合計 4,380
