はじめに
The battery is the main power supply to the laptop. Keeping a healthy battery is good for your device's health. A worn out battery can cause overheating of the device and it will have a shorter battery life. The removal of the battery is fairly simple and this guide will show you how to remove it. You will need a plastic opening tool and a Phillips #0 screwdriver.
必要な工具と部品
Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
4 の人々がこのガイドを完成させました。
コメント 1 件
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
