メインコンテンツにスキップ
Dell XPS 14 L401X Palm Rest Replacement
必要な工具と部品
  1. Dell XPS 14 L401X Palm Rest Replacement, Battery: 手順 1、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement, Battery: 手順 1、 2の画像 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Palm Rest Replacement, RAM: 手順 2、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement, RAM: 手順 2、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement, RAM: 手順 2、 3の画像 3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Palm Rest Replacement: 手順 3、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 3、 2の画像 2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Palm Rest Replacement, Optical Drive: 手順 4、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement, Optical Drive: 手順 4、 2の画像 2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Palm Rest Replacement: 手順 5、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 5、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 5、 3の画像 3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Palm Rest Replacement: 手順 6、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 6、 2の画像 2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Palm Rest Replacement: 手順 7、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 7、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 7、 3の画像 3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
  8. Dell XPS 14 L401X Palm Rest Replacement, Hard Drive: 手順 8、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement, Hard Drive: 手順 8、 2の画像 2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  9. Dell XPS 14 L401X Palm Rest Replacement: 手順 9、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 9、 2の画像 2
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  10. Dell XPS 14 L401X Palm Rest Replacement: 手順 10、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 10、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 10、 3の画像 3
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
  11. Dell XPS 14 L401X Palm Rest Replacement, Mini Card: 手順 11、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement, Mini Card: 手順 11、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement, Mini Card: 手順 11、 3の画像 3
    • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
    • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
    • The captive screw will not come off of the panel.
    • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
  12. Dell XPS 14 L401X Palm Rest Replacement: 手順 12、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 12、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 12、 3の画像 3
    • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
    • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
    • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
  13. Dell XPS 14 L401X Palm Rest Replacement: 手順 13、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 13、 2の画像 2
    • Remove the mini card as it flips upward.
  14. Dell XPS 14 L401X Palm Rest Replacement, Palm Rest: 手順 14、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement, Palm Rest: 手順 14、 2の画像 2
    • Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
  15. Dell XPS 14 L401X Palm Rest Replacement: 手順 15、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 15、 2の画像 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K"in the hard drive bay.
  16. Dell XPS 14 L401X Palm Rest Replacement: 手順 16、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 16、 2の画像 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K" near Battery
  17. Dell XPS 14 L401X Palm Rest Replacement: 手順 17、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 17、 2の画像 2
    • Remove (1) 7.5mm screw with JIS 1 screwdriver marked by the letter "K" in the RAM bay.
  18. Dell XPS 14 L401X Palm Rest Replacement: 手順 18、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 18、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 18、 3の画像 3
    • Open the display to provide room for the palm rest to come out.
    • In the hard drive bay, push the "push" pad to lift up the palm rest.
  19. Dell XPS 14 L401X Palm Rest Replacement: 手順 19、 3の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 19、 3の画像 2 Dell XPS 14 L401X Palm Rest Replacement: 手順 19、 3の画像 3
    • Disconnect the track pad cable by flipping up the gray clamp and lifting the cable up.
  20. Dell XPS 14 L401X Palm Rest Replacement: 手順 20、 2の画像 1 Dell XPS 14 L401X Palm Rest Replacement: 手順 20、 2の画像 2
    • Disconnect the status bar cable by pulling the pin connector upward.
    • Finish lifting up the palm rest.
終わりに
作成者
3人の作成者と共同で作成されました。
Phelan Mascitelli
メンバー登録日: 10/19/17
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G3
3 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 362
