メインコンテンツにスキップ
Dell XPS 14 L401X Optical Drive Replacement
必要な工具と部品
  1. Dell XPS 14 L401X Optical Drive Replacement, Battery: 手順 1、 2の画像 1 Dell XPS 14 L401X Optical Drive Replacement, Battery: 手順 1、 2の画像 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Optical Drive Replacement, RAM: 手順 2、 3の画像 1 Dell XPS 14 L401X Optical Drive Replacement, RAM: 手順 2、 3の画像 2 Dell XPS 14 L401X Optical Drive Replacement, RAM: 手順 2、 3の画像 3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Optical Drive Replacement: 手順 3、 2の画像 1 Dell XPS 14 L401X Optical Drive Replacement: 手順 3、 2の画像 2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Optical Drive Replacement, Optical Drive: 手順 4、 2の画像 1 Dell XPS 14 L401X Optical Drive Replacement, Optical Drive: 手順 4、 2の画像 2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Optical Drive Replacement: 手順 5、 3の画像 1 Dell XPS 14 L401X Optical Drive Replacement: 手順 5、 3の画像 2 Dell XPS 14 L401X Optical Drive Replacement: 手順 5、 3の画像 3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Optical Drive Replacement: 手順 6、 2の画像 1 Dell XPS 14 L401X Optical Drive Replacement: 手順 6、 2の画像 2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Optical Drive Replacement: 手順 7、 3の画像 1 Dell XPS 14 L401X Optical Drive Replacement: 手順 7、 3の画像 2 Dell XPS 14 L401X Optical Drive Replacement: 手順 7、 3の画像 3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
終わりに
作成者
2人の作成者と共同で作成されました。
Mark
メンバー登録日: 10/19/17
655 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G3
3 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 367
