メインコンテンツにスキップ
Dell XPS 13 9365 2-in-1 Touchpad Replacement
必要な工具と部品
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: 手順 1、 1の画像 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 2、 1の画像 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 3、 1の画像 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 4、 1の画像 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 5、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 6、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 7、 1の画像 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 手順 8、 3の画像 1 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 手順 8、 3の画像 2 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 手順 8、 3の画像 3
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 9、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 10、 2の画像 1 Dell XPS 13 9365 2-in-1 Touchpad Replacement: 手順 10、 2の画像 2
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
終わりに
作成者
1人の作成者と共同作成されました。
Melissa Schlein
メンバー登録日: 03/21/22
701 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 3-4, Bedsole Spring 2022 University of Alabama, Team 3-4, Bedsole Spring 2022人のメンバー
UA-BEDSOLE-S22S3G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 34
今までの合計 699
