メインコンテンツにスキップ
Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement
必要な工具と部品
  1. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Battery: 手順 1、 1の画像 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 2、 1の画像 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 3、 1の画像 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 4、 1の画像 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 5、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 6、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 7、 1の画像 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Removing the Solid-State Drive: 手順 8、 1の画像 1
    • Peel off the display cable tape from the hard-drive plate.
  9. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 9、 1の画像 1
    • Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
  10. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 10、 1の画像 1
    • Remove the hard-drive plate.
  11. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 手順 11、 1の画像 1
    • Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
    • Solid-state drives are fragile. Exercise care when handling the solid-state drive.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,058 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,984のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 45
今までの合計 6,135
