必要な工具と部品
Turn the tablet over.
Remove the screws that secure the back-cover assembly to the display assembly.
Using a plastic scribe, pry up along the edges of the back-cover assembly.
Carefully, lift the back-cover assembly and turn it over.
Remove the screws that secure the battery to the back-cover assembly.
Disconnect the battery cable from the system board.
Lift the battery, along with its cable, off the back-cover assembly.
Remove the screw that secures the solid-state drive to the back-cover assembly.
Lift and slide the solid-state drive off the back-cover assembly.
ある他の人がこのガイドを完成しました。
