メインコンテンツにスキップ
Dell XPS 10 USB Port Replacement
必要な工具と部品
  1. Dell XPS 10 USB Port Replacement, Battery: 手順 1、 3の画像 1 Dell XPS 10 USB Port Replacement, Battery: 手順 1、 3の画像 2 Dell XPS 10 USB Port Replacement, Battery: 手順 1、 3の画像 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 USB Port Replacement: 手順 2、 3の画像 1 Dell XPS 10 USB Port Replacement: 手順 2、 3の画像 2 Dell XPS 10 USB Port Replacement: 手順 2、 3の画像 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
  3. Dell XPS 10 USB Port Replacement, USB Port: 手順 3、 3の画像 1 Dell XPS 10 USB Port Replacement, USB Port: 手順 3、 3の画像 2 Dell XPS 10 USB Port Replacement, USB Port: 手順 3、 3の画像 3
    • Use the plastic opening tools to lift up the black cable shown in the picture.
    • Slide one end of the speaker to the other side and the speaker will be out.
  4. Dell XPS 10 USB Port Replacement: 手順 4、 3の画像 1 Dell XPS 10 USB Port Replacement: 手順 4、 3の画像 2 Dell XPS 10 USB Port Replacement: 手順 4、 3の画像 3
    • Unscrew the shown screw in the picture.
    • Remove the silver tape using the plastic tool as shown in the picture.
    • Note: be careful when removing the tape as it is fragile.
  5. Dell XPS 10 USB Port Replacement: 手順 5、 3の画像 1 Dell XPS 10 USB Port Replacement: 手順 5、 3の画像 2 Dell XPS 10 USB Port Replacement: 手順 5、 3の画像 3
    • Unscrew the three screws shown in the picture.
    • 3 mm screws.
    • Slide the small piece shown in green square on both black pieces and lift them up using the plastic tool as shown in the picture.
    • Finally, take the USB port out. You will have three pieces out: the port and the two black pieces as shown in the picture.
終わりに
作成者
3人の作成者と共同で作成されました。
James
メンバー登録日: 10/04/16
401 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016人のメンバー
USFT-NANCE-F16S2G1
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 1,996
