メインコンテンツにスキップ
Dell XPS 10 Speakers Replacement
必要な工具と部品
  1. Dell XPS 10 Speakers Replacement, Battery: 手順 1、 3の画像 1 Dell XPS 10 Speakers Replacement, Battery: 手順 1、 3の画像 2 Dell XPS 10 Speakers Replacement, Battery: 手順 1、 3の画像 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Speakers Replacement: 手順 2、 3の画像 1 Dell XPS 10 Speakers Replacement: 手順 2、 3の画像 2 Dell XPS 10 Speakers Replacement: 手順 2、 3の画像 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
  3. Dell XPS 10 Speakers Replacement, Speakers: 手順 3、 3の画像 1 Dell XPS 10 Speakers Replacement, Speakers: 手順 3、 3の画像 2 Dell XPS 10 Speakers Replacement, Speakers: 手順 3、 3の画像 3
    • Use the opening tools to unplug the gold/orange ribbon cable.
    • Use the opening tools to unplug the speakers from the motherboard.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws.
    • Use a Phillips #0 screwdriver to remove two 3 mm screws.
    • Do not miss the screw under the gold/orange ribbon cable.
  4. Dell XPS 10 Speakers Replacement: 手順 4、 3の画像 1 Dell XPS 10 Speakers Replacement: 手順 4、 3の画像 2 Dell XPS 10 Speakers Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tools to lift up the black cable.
    • While holding the cable up, slide one end of the speaker to the other side under the cable and remove the speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
saraspam
メンバー登録日: 09/28/16
244 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016人のメンバー
USFT-NANCE-F16S2G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 325
