メインコンテンツにスキップ
Dell Vostro V130 Hard Drive and Audio Board Removal
必要な工具と部品
  1. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 手順 1、 1の画像 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Base Cover: 手順 2、 1の画像 1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Battery: 手順 3、 1の画像 1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove Battery Screws: 手順 4、 1の画像 1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Hard Drive and Audio Board Removal, Lift the Battery: 手順 5、 1の画像 1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Speaker: 手順 6、 1の画像 1
    • Disconnect the speaker and system board cables from the audio board.
  7. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 手順 7、 1の画像 1
    • Remove the screws that secure the audio board and the hard drive to the computer.
  8. Dell Vostro V130 Hard Drive and Audio Board Removal, Lifting the Hard Drive and Audio Board: 手順 8、 1の画像 1
    • Lift and remove the hard drive and audio board assembly from the computer.
  9. Dell Vostro V130 Hard Drive and Audio Board Removal, Sliding the Audio Board: 手順 9、 1の画像 1
    • Slide the audio board from the hard drive.
  10. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 手順 10、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  11. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Hard Drive: 手順 11、 1の画像 1
    • Remove the hard drive from the hard-drive bracket.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,237 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 15
今までの合計 645
