はじめに
Once you have removed the back cover and gain access to the internal components of the Dell Vostro 15 5510, once of the components you will be able to replace is the fan. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. You will not need to do any difficult steps, but take care to disconnect the antenna cables carefully.
必要な工具と部品
ある他の人がこのガイドを完成しました。
