はじめに
To gain any access to the internal components of the Dell Vostro 15 5510 the back cover will have to be removed. Once the back cover is removed, you can remove and replace the battery. In order to complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. Ensure to unscrew all screws to prevent any battery or battery input damage.
必要な工具と部品
Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
ある他の人がこのガイドを完成しました。
