はじめに
This guide will walk through all the necessary steps in order to replace the fan for the Dell Vostro 3550. A common problem that would require the device owner to replace their fan is if a fan blade breaks due to a piece of debris that entered the fan mechanism. This can often be determined if the fan is making loud and unusual noises as the computer is running.
必要な工具と部品
Turn the laptop right side up. Open the display to reveal the keyboard.
Use the metal spudger to pry the keyboard upward from the base. Make sure to pop each of the three clips keeping the keyboard in place.
Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
Lift the access panel up at an angle and remove it from the computer.
Remove the two 5mm Phillips #0 screws that secure the hard drive to the system.
Remove the four 5mm Phillips #0 screws that secure the hard drive bracket to the hard drive.
Remove the five 7mm Phillips #0 screws fastening the aluminum side panels to the laptop.
3 の人々がこのガイドを完成させました。
