メインコンテンツにスキップ
Dell Vostro 3500 WiFi Card Replacement
必要な工具と部品
  1. Dell Vostro 3500 WiFi Card Replacement, Sliding the Battery Latch: 手順 1、 1の画像 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 WiFi Card Replacement, Sliding the Battery Release Latch: 手順 2、 1の画像 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 WiFi Card Replacement, Removing the Battery: 手順 3、 1の画像 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 WiFi Card Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 WiFi Card Replacement, Removing the Base Cover: 手順 5、 1の画像 1
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 WiFi Card Replacement, WiFi card removal: 手順 6、 1の画像 1
    • Gently snap off the two aerial connectors from the WiFi card.
    • On reassembly they simply snap back on with firm pressure, but first make sure they are positioned correctly over their sockets.
    • Remove a single screw adjacent to one of the aerial sockets retaining the wWiFi card, then lift it out.
    • On resassembly, ensure that the WiFi card is fully inserted into its sovket before angling it down and reinserting the screw.
終わりに
作成者
1人の作成者と共同作成されました。
Philip Le Riche
メンバー登録日: 02/18/14
30,795 ポイント
47のガイドは作成済み
チーム
Restart Project Restart Project人のメンバー
Local Repair Groups
23 メンバー
661のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 25
今までの合計 1,147
