メインコンテンツにスキップ
Dell Vostro 3500 Keyboard Replacement
必要な工具と部品
  1. Dell Vostro 3500 Keyboard Replacement, Sliding the Battery Latch: 手順 1、 1の画像 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 Keyboard Replacement, Sliding the Battery Release Latch: 手順 2、 1の画像 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 Keyboard Replacement, Removing the Battery: 手順 3、 1の画像 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • There are 4 tabs along the top of the keyboard and two along each side which need to be released. The iFixit Jimmy is ideal for this, but you can use a thin spatula.
    • Feel along the gap with the jimmy until you come to a tab. Angle the jimmy away from the keyboard in order to release the tab. As you release each tab, gently lift that part of the keyboard in order to encourage the next tab to disengage, but take care not to bend it.
  5. Dell Vostro 3500 Keyboard Replacement: 手順 5、 1の画像 1
    • Lift the top edge of the keyboard and turn it over, laying it flat.
    • Very gently lift the black retaining tab on the keyboard ribbon and withdraw the ribbon.
    • On reassembly, make sure the ribbon is fully inserted in its socket before pressing down the tab.
終わりに
作成者
1人の作成者と共同作成されました。
Philip Le Riche
メンバー登録日: 02/18/14
30,816 ポイント
47のガイドは作成済み
チーム
Restart Project Restart Project人のメンバー
Local Repair Groups
23 メンバー
663のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 45
今までの合計 1,778
