メインコンテンツにスキップ
Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement
必要な工具と部品
  1. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Unlocking the Battery: 手順 1、 1の画像 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Battery: 手順 2、 1の画像 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Keyboard: 手順 3、 1の画像 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Keyboard retainer: 手順 4、 1の画像 1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pry up the Keyboard Retainer: 手順 5、 1の画像 1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Retainer: 手順 6、 1の画像 1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pull up the Keyboard: 手順 7、 1の画像 1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latch: 手順 8、 1の画像 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Loosen the Screw: 手順 9、 1の画像 1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Memory Door: 手順 10、 1の画像 1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screw: 手順 11、 1の画像 1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Drive: 手順 12、 1の画像 1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: 手順 13、 1の画像 1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Removing the Optical Drive: 手順 14、 1の画像 1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: 手順 15、 1の画像 1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: 手順 16、 1の画像 1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Rubber: 手順 17、 1の画像 1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Rubber: 手順 18、 1の画像 1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: 手順 19、 1の画像 1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screws: 手順 20、 1の画像 1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latches: 手順 21、 1の画像 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Release the Latch: 手順 22、 1の画像 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Disconnecting the Key Cable: 手順 23、 1の画像 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Palm Rest: 手順 24、 1の画像 1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Palm Rest: 手順 25、 1の画像 1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Prying the Sides: 手順 26、 1の画像 1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Remove the Screw: 手順 27、 1の画像 1
    • Remove the screw that secures the WLAN card.
  28. Dell Vostro 3450 Wireless Local Area Network (WLAN) Card Replacement, Pull the Card: 手順 28、 1の画像 1
    • Pull the WLAN card straight out of its socket and remove it.
ゴール
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,034 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
コメント 1 件
Thank you so much. It is very helpful!
-Anosh
Anosh Shrestha - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 26
今までの合計 1,015
