メインコンテンツにスキップ
Dell Vostro 3450 System Board Replacement
必要な工具と部品
  1. Dell Vostro 3450 System Board Replacement, Unlocking the Battery: 手順 1、 1の画像 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Board Replacement, Removing the Battery: 手順 2、 1の画像 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Board Replacement, Press the ExpressCard: 手順 3、 1の画像 1
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 System Board Replacement, Slide the ExpressCard: 手順 4、 1の画像 1
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 System Board Replacement, Prying the Keyboard: 手順 5、 1の画像 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 System Board Replacement, Prying the Keyboard retainer: 手順 6、 1の画像 1
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 System Board Replacement, Pry up the Keyboard Retainer: 手順 7、 1の画像 1
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 System Board Replacement, Prying the Retainer: 手順 8、 1の画像 1
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 System Board Replacement, Pull up the Keyboard: 手順 9、 1の画像 1
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 System Board Replacement, Release the Latch: 手順 10、 1の画像 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 System Board Replacement, Loosen the Screw: 手順 11、 1の画像 1
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 System Board Replacement, Removing the Memory Door: 手順 12、 1の画像 1
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 System Board Replacement, Remove the Screw: 手順 13、 1の画像 1
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 System Board Replacement, Prying the Drive: 手順 14、 1の画像 1
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 15、 1の画像 1
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 System Board Replacement, Removing the Optical Drive: 手順 16、 1の画像 1
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 17、 1の画像 1
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 18、 1の画像 1
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 System Board Replacement, Remove the Rubber: 手順 19、 1の画像 1
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 System Board Replacement, Remove the Rubber: 手順 20、 1の画像 1
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 21、 1の画像 1
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 22、 1の画像 1
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 System Board Replacement, Release the Latches: 手順 23、 1の画像 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 System Board Replacement, Release the Latch: 手順 24、 1の画像 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 System Board Replacement, Disconnecting the Key Cable: 手順 25、 1の画像 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: 手順 26、 1の画像 1
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: 手順 27、 1の画像 1
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 System Board Replacement, Prying the Sides: 手順 28、 1の画像 1
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 29、 1の画像 1
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 System Board Replacement, Press Down on the Hooks: 手順 30、 1の画像 1
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 System Board Replacement, Removing the Hinge Cover: 手順 31、 1の画像 1
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 32、 1の画像 1
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 System Board Replacement, Loosen the Screw: 手順 33、 1の画像 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 System Board Replacement, Disconnecting the LVDS Cable: 手順 34、 1の画像 1
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 System Board Replacement, Disconnecting the Wireless Cables: 手順 35、 1の画像 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 36、 1の画像 1
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 37、 1の画像 1
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 System Board Replacement, Lifting the Display Assembly: 手順 38、 1の画像 1
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 System Board Replacement, Remove the Screw: 手順 39、 1の画像 1
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 System Board Replacement, Pull the Card: 手順 40、 1の画像 1
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 System Board Replacement, Release the Latch: 手順 41、 1の画像 1
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 System Board Replacement, Remove the Screw: 手順 42、 1の画像 1
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 System Board Replacement, Remove the VGA Board: 手順 43、 1の画像 1
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 System Board Replacement, Disconnect the System Fan Cable: 手順 44、 1の画像 1
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 System Board Replacement, Remove the Screw: 手順 45、 1の画像 1
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 System Board Replacement, Remove the System Fan: 手順 46、 1の画像 1
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 System Board Replacement, Disconnect the DC-in Cable: 手順 47、 1の画像 1
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 System Board Replacement, Disconnecting the Speaker Cable: 手順 48、 1の画像 1
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 System Board Replacement, Remove the Screws: 手順 49、 1の画像 1
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 System Board Replacement, Disconnecting the System Board: 手順 50、 1の画像 1
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 System Board Replacement, Remove the System Board: 手順 51、 1の画像 1
    • Lift and remove system board from the chassis.
ゴール
作成者
2人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,034 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 431
