はじめに
In this guide, we will be showing you how to remove and replace the Palm Rest.
必要な工具と部品
Slide the left and the right battery release latches to the unlock position.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
ある他の人がこのガイドを完成しました。
