この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Slide the left and the right battery release latches to the unlock position.
Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
Release the latch on the system board connector, then disconnect the keyboard cable.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
Disconnect the wireless local area network (WLAN) antenna cable.
4 の人々がこのガイドを完成させました。
4 件のコメント
Who the !&&* designs a hard drive location that requires complete disassembly of the motherboard and the laptop to replace. Horrible, horrible design.
