メインコンテンツにスキップ
Dell Vostro 3360 Hard Drive Replacement
必要な工具と部品
  1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: 手順 1、 1の画像 1
    • Remove the screw that secures the keyboard to the chassis.
  2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: 手順 2、 1の画像 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: 手順 3、 1の画像 1
    • Flip the keyboard over and lay it on the palmrest.
  4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: 手順 4、 1の画像 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: 手順 5、 1の画像 1
    • Remove the screw that secures the access panel to the computer.
  6. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: 手順 6、 1の画像 1
    • Remove the access panel from the computer.
  7. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: 手順 7、 1の画像 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: 手順 8、 1の画像 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: 手順 9、 1の画像 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: 手順 10、 1の画像 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: 手順 11、 1の画像 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: 手順 12、 1の画像 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: 手順 13、 1の画像 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: 手順 14、 1の画像 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: 手順 15、 1の画像 1
    • Lift the palm-rest up and away from the computer.
  16. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: 手順 16、 1の画像 1
    • Remove the screws that secure the hard drive to the computer.
  17. Dell Vostro 3360 Hard Drive Replacement: 手順 17、 1の画像 1
    • Lift the hard drive to disconnect the hard-drive cable
  18. Dell Vostro 3360 Hard Drive Replacement: 手順 18、 1の画像 1
    • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
  19. Dell Vostro 3360 Hard Drive Replacement: 手順 19、 1の画像 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,237 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 3,360
