必要な工具と部品
Loosen the M2.5x2+3.5 captive screws that secure the base cover to the computer [1].
Pry the base cover from the edge [2].
Lift the base cover away from the computer
Disconnect the battery cable from the connector on the system board [1].
Remove the M2x3L screws that secure the battery to the computer [2].
Pry the clips securing the memory module until the memory pops-up [1]
Lift the memory module away from the connector [2].
ある他の人がこのガイドを完成しました。
