メインコンテンツにスキップ
Dell Vostro 15 5568 Hard Drive Replacement
必要な工具と部品
  1. Dell Vostro 15 5568 Hard Drive Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the screws that secure the back cover to the computer.
  2. Dell Vostro 15 5568 Hard Drive Replacement: 手順 2、 1の画像 1
    • Using a scribe, pry the edges of the back cover from all sides [1].
    • Lift the back cover from the computer [2].
  3. Dell Vostro 15 5568 Hard Drive Replacement, Battery: 手順 3、 1の画像 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  4. Dell Vostro 15 5568 Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Lift the tab to disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Johnathan Hammond
メンバー登録日: 02/28/18
45,237 ポイント
408のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
2件のガイドコメント
Did work for me, many thanks. Only two small remarks.
a) Why remove the battery? I was installing a SSD in addition to the built in one (the hdd place was still empty). Attaching the hdd cable is possible without battery removal.
b) Disonnecting the battery showed to be a bit tricky. Pulling the cable is out of question, and pulling at the label part looked also not advisable. One-sided prying…not so good. Pushing the connector in the plane of the battery - need to be very careful, slipping may mean impulse force to the cable. I used careful two sided prying into the small spaces left and right of the connector.
Wolfgang - 返信
Cuál es el tamaño de los tornillos de la cubierta posterior?
Elisa de Torres - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 3,724
