必要な工具と部品
Slide the latches outward [1]
Release the battery [2].
Lift the battery to remove it from the computer.
Loosen the screw that secures access panel to computer [1].
Slide the access panel from the computer [2].
Lift the access panel off the computer.
Pry the securing clips away from the memory module until it pops up.
Remove the memory module from its socket on the system board.
ある他の人がこのガイドを完成しました。
