メインコンテンツにスキップ
Dell Vostro 1400 Screen Replacement
必要な工具と部品
  1. Dell Vostro 1400 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: 手順 2、 1の画像 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: 手順 3、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 3、 2の画像 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: 手順 4、 1の画像 1
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: 手順 5、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 5、 2の画像 2
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: 手順 6、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 6、 2の画像 2
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: 手順 7、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 7、 2の画像 2
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: 手順 8、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 8、 2の画像 2
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: 手順 9、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 9、 2の画像 2
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: 手順 10、 3の画像 1 Dell Vostro 1400 Screen Replacement: 手順 10、 3の画像 2 Dell Vostro 1400 Screen Replacement: 手順 10、 3の画像 3
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: 手順 11、 2の画像 1 Dell Vostro 1400 Screen Replacement: 手順 11、 2の画像 2
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
David Hogg
メンバー登録日: 03/20/17
727 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 650
