メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Venue 8 Display Replacement
必要な工具と部品
  1. Dell Venue 8 Display Replacement, Rear Case/Midframe: 手順 1、 1の画像 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
    FixBotに聞いてみる
    コメントを追加
  2. Dell Venue 8 Display Replacement: 手順 2、 3の画像 1 Dell Venue 8 Display Replacement: 手順 2、 3の画像 2 Dell Venue 8 Display Replacement: 手順 2、 3の画像 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
    FixBotに聞いてみる
    コメントを追加
  3. Dell Venue 8 Display Replacement, Battery: 手順 3、 1の画像 1
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
    FixBotに聞いてみる
    コメントを追加
  4. Dell Venue 8 Display Replacement: 手順 4、 1の画像 1
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
    FixBotに聞いてみる
    コメントを追加
  5. Dell Venue 8 Display Replacement, Speaker: 手順 5、 1の画像 1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
    FixBotに聞いてみる
    コメントを追加
  6. Dell Venue 8 Display Replacement: 手順 6、 1の画像 1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
    FixBotに聞いてみる
    コメントを追加
  7. Dell Venue 8 Display Replacement, Display: 手順 7、 2の画像 1 Dell Venue 8 Display Replacement, Display: 手順 7、 2の画像 2
    • Disconnect the display clip found next to the speaker.
    • Disconnect the Display connection located at the top of the tablet.
    FixBotに聞いてみる
    コメントを追加
  8. Dell Venue 8 Display Replacement: 手順 8、 1の画像 1
    • Unclip the logic board from the Display.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mitul
メンバー登録日: 02/19/15
673 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G2
3 メンバー
12のガイドは作成済み
2件のガイドコメント
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - 返信 共有
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 7,684
