メインコンテンツにスキップ
はじめに
Your battery in your tablet may not be working. We will be replacing the battery of the Dell Venue 8.
  1. Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws) The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image 4.45mm Silver screws
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Gently pry the battery away from the device with the plastic opening tool to remove it.
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
終わりに
13 の人々がこのガイドを完成させました。
Andrea
メンバー登録日: 2015年02月19日
1,044 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G2
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 11,203
