はじめに
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
必要な工具と部品
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
8 の人々がこのガイドを完成させました。
2 件のコメント
unable to open the lock, can the mother board be changed
Great article.
