はじめに
This replacement guide will show you how to replace the HDMI/USB cable on your Dell VRP100 headset. With the right tools, this will be a quick and easy replacement.
必要な工具と部品
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
この手順で使用する道具:Tweezers$4.99
Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
Peel off the tape using your hands or the blunt nose tweezers.
5 の人々がこのガイドを完成させました。
6件のガイドコメント
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
Me too, looking for a cable replacement.
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
Tom Powell - 返信
I am also looking for a replacement cable. Could it be soldered on from another cable?
