はじめに
Some reasons you would want to replace the camera in the Dell VRP100 are screen image drifting, image freezing, or tracking/calibration issues. You should be cautious when removing the camera, so the camera lens does not get scratched in the process.
必要な工具と部品
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
Separate the lens housing from the motherboard panel.
もう少しです!
終わりに
