必要な工具と部品
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
Remove the 8 8mm ph1 philips head screws (red)
Remove also the one 4mm ph 1 philips head screw (blue)
2 の人々がこのガイドを完成させました。
