必要な工具と部品
Loosen the eight captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
Remove the four screws securing the hard drive assembly to the computer base.
Pull the blue pull-tab on the cable attached to the system board to disconnect the cable.
Pull the black pull-tab to lift the hard drive assembly out of the computer.
ある他の人がこのガイドを完成しました。
