この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
必要な工具と部品
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
2 の人々がこのガイドを完成させました。
