この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your screen becomes unresponsive you may need to replace it. A Philips 1 screwdriver and a plastic opening tool are required for this guide.
必要な工具と部品
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Insert a plastic opening tool between the bezel and the display cover.
Wiggle it to the release the latches.
Separate the bezel from the cover.
3 の人々がこのガイドを完成させました。
