このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
If you look at the bottom of the laptop, you will notice that there is a panel that is removable
Unscrew the screws that hold the panel in place
Unscrew the screws until they are loose. They will not come out of the panel
After loosening all the screws, lift the panel up from the main chassis
You may need to use a flathead screwdriver to lift the panel
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Tweezers$4.99-
Now we have access to the internals of the laptop, pretty neat
If the battery is away from you, the hard drive should be closer towards you on the left
Start by removing the screws holding the caddy into the chassis
These screws have a more rounded top, and are longer
Once loosened, you can remove with your fingers or tweezers, and then set them aside
この手順は未翻訳です。 翻訳を手伝う。
Now we remove the screws holding the drive to the caddy
These screws are have a flatter head, and are shorter
These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
Set these screws aside, apart from the screws we removed in the last step
この手順は未翻訳です。 翻訳を手伝う。
If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
Pull this tab gently in order to remove the cable
Again, wiggling also helps
この手順は未翻訳です。 翻訳を手伝う。
If you removed the drive using steps 1-7 then what you have should be left in picture 1
If you had trouble removing the drive, and you went through to step 8, then the parts remaining will be in picture 2
The drive should have a SATA interface, so you should be able to mount it into another computer using 2.5" to 3.5" converter brackets and a SATA cable
12 の人々がこのガイドを完成させました。
