はじめに
First read the Teardown from ifixit.com for the Dell Streak Phone
パーツ
パーツは必要ありません。
  1. Loosen any clamps that hold the LCD screen in place. Some of the clamps may not be loosened yet, leave them attached for now. Loosen any clamps that hold the LCD screen in place. Some of the clamps may not be loosened yet, leave them attached for now. Loosen any clamps that hold the LCD screen in place. Some of the clamps may not be loosened yet, leave them attached for now.
    • Loosen any clamps that hold the LCD screen in place. Some of the clamps may not be loosened yet, leave them attached for now.
  2. The gorilla glass is pinned to the case. You must take a slotted screwdriver  to go around the case and separate the gorilla glass from the case. In some instances the gorilla glass may seperate from the LCD fairly easily, or it maybe hard to release.
    • The gorilla glass is pinned to the case. You must take a slotted screwdriver to go around the case and separate the gorilla glass from the case.
    • In some instances the gorilla glass may seperate from the LCD fairly easily, or it maybe hard to release.
    • (Don't feel sorry for the broken display, it doesn't deserve to be treated gently..)
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Lift the new display out of the case. You should fold the LCD ribbon cable to do this. Lift the new display out of the case. You should fold the LCD ribbon cable to do this. Lift the new display out of the case. You should fold the LCD ribbon cable to do this.
    • Lift the new display out of the case. You should fold the LCD ribbon cable to do this.
  5. Really good, the display is out of the case. Remember the lifted display is no longer for use. For example, i brought the touchscreen ribbon cable even though i was careful.
    • Really good, the display is out of the case.
    • Remember the lifted display is no longer for use. For example, i brought the touchscreen ribbon cable even though i was careful.
  6. Insert the brand new display! Remind, you must do step 3 to 2 in reversed direction. The hardest part for me was to fold the LCD ribbon cable of the new display, but don't be shy, do it!
    • Insert the brand new display! Remind, you must do step 3 to 2 in reversed direction. The hardest part for me was to fold the LCD ribbon cable of the new display, but don't be shy, do it!
    • Reassemble your Phone
  7. Perfect, it's done! Don't be alarmed if the screen is black when you re-start your phone for the first time and the buttons are only glowing. This may happen, but removing and reinserting the battery should restart it and cause it to function properly!
    • Perfect, it's done!
    • Don't be alarmed if the screen is black when you re-start your phone for the first time and the buttons are only glowing. This may happen, but removing and reinserting the battery should restart it and cause it to function properly!
まとめ
ある他の人がこのガイドを完成しました。
Fix my problems myself
メンバー登録日: 2010年12月10日
71 ポイント
1ガイドが承認済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 23,156
