メインコンテンツにスキップ
Dell Precision T5600 RAM Replacement
  1. Dell Precision T5600 RAM Replacement, RAM: 手順 1、 1の画像 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
    • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Dell Precision T5600 RAM Replacement: 手順 2、 1の画像 1
    • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
    • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
  3. Dell Precision T5600 RAM Replacement: 手順 3、 2の画像 1 Dell Precision T5600 RAM Replacement: 手順 3、 2の画像 2
    • Line up the RAM with the groove on the connector line.
    • Do not touch the gold connectors.
  4. Dell Precision T5600 RAM Replacement: 手順 4、 2の画像 1 Dell Precision T5600 RAM Replacement: 手順 4、 2の画像 2
    • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
    • Ensure that both ends of the RAM are secured by their tabs.
  5. Dell Precision T5600 RAM Replacement: 手順 5、 1の画像 1
    • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
    • Once powered on, to verify the installation:
    • Right-click on 'This PC'
    • Left-click on 'Properties'
終わりに
作成者
3人の作成者と共同で作成されました。
Fahad Khan
メンバー登録日: 07/05/21
133 ポイント
1ガイドが承認済み
チーム
York University, Team S70-G120, Allen Summer 2021 York University, Team S70-G120, Allen Summer 2021人のメンバー
YORK-ALLEN-SU21S70G120
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 31
今までの合計 557
