メインコンテンツにスキップ
Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 手順 1、 2の画像 1 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 手順 1、 2の画像 2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
  2. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: 手順 2、 1の画像 1
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
  3. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 手順 3、 2の画像 1 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 手順 3、 2の画像 2
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
  4. Dell Precision T3400 Video Card Replacement, Remove the video card: 手順 4、 1の画像 1
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
  5. Dell Precision T3400 Video Card Replacement, Install the new video card: 手順 5、 2の画像 1 Dell Precision T3400 Video Card Replacement, Install the new video card: 手順 5、 2の画像 2
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.\
    • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
終わりに
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
8 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Josette Cormier
メンバー登録日: 09/10/13
13 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S1G2
3 メンバー
14のガイドは作成済み
コメント 1 件
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 33
今までの合計 6,545
