必要な工具と部品
Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
Using Phillips screwdriver, remove 2 screws holding case.
Slide case towards back of laptop then lift off to remove.
Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
4 の人々がこのガイドを完成させました。
コメント 1 件
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
