メインコンテンツにスキップ
Dell Precision M4800 Wi-Fi Card Replacement
必要な工具と部品
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 手順 1、 3の画像 1 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 手順 1、 3の画像 2 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: 手順 1、 3の画像 3
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
  2. Dell Precision M4800 Wi-Fi Card Replacement: 手順 2、 3の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 2、 3の画像 2 Dell Precision M4800 Wi-Fi Card Replacement: 手順 2、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: 手順 3、 3の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 3、 3の画像 2 Dell Precision M4800 Wi-Fi Card Replacement: 手順 3、 3の画像 3
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
  4. Dell Precision M4800 Wi-Fi Card Replacement: 手順 4、 2の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 4、 2の画像 2
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: 手順 5、 2の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 5、 2の画像 2
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
  6. Dell Precision M4800 Wi-Fi Card Replacement: 手順 6、 2の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 6、 2の画像 2
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: 手順 7、 3の画像 1 Dell Precision M4800 Wi-Fi Card Replacement: 手順 7、 3の画像 2 Dell Precision M4800 Wi-Fi Card Replacement: 手順 7、 3の画像 3
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
終わりに
作成者
1人の作成者と共同作成されました。
Naveen
メンバー登録日: 09/19/23
195 ポイント
1ガイドが承認済み
チーム
York University, Team B-19, Woodhouse Fall 2023 York University, Team B-19, Woodhouse Fall 2023人のメンバー
YORK-WOODHOUSE-F23SBG19
2 メンバー
1のガイドは作成済み
コメント 1 件
Great guide, well-written and concise. Thank you for sharing your knowledge and expertise. Best regards
Loren Martin - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 52
今までの合計 419
