メインコンテンツにスキップ
Dell Precision 7560 Solid-State Drive (SSD) Replacement
必要な工具と部品
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 手順 1、 3の画像 1 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 手順 1、 3の画像 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 手順 1、 3の画像 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 2、 3の画像 1 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 2、 3の画像 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 2、 3の画像 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 3、 3の画像 1 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 3、 3の画像 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 3、 3の画像 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 手順 4、 2の画像 1 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 手順 4、 2の画像 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 5、 2の画像 1 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 手順 5、 2の画像 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
終わりに
作成者
3人の作成者と共同で作成されました。
Hector
メンバー登録日: 02/14/23
249 ポイント
2のガイドは作成済み
チーム
Utah Tech University, Team 1-1, McMurrin Spring 2023 Utah Tech University, Team 1-1, McMurrin Spring 2023人のメンバー
UTAHTECH-MCMURRIN-S23S1G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 47
今までの合計 490
