はじめに
The guide shows how to remove the keyboard from a Dell Precision 7560. The keyboard is a core component of the computer, so keeping on top of its maintenance is vital. If the issue with the keyboard isn't merely debris keeping a key from functioning, then this guide will assist you in replacing the keyboard entirely.
必要な工具と部品
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
Pulling from the tab, carefully remove the connector.
2 の人々がこのガイドを完成させました。
コメント 1 件
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - 返信
