はじめに
A guide from dell can be found in the Service Manual, Archive.org links to specific steps Removing The Base Cover, Removeing SSD, Installing SS and Installing The Base Cover
必要な工具と部品
I found the device surface pretty slipery so I would advise something than can both protect and prevent it to move so you can work easily
Ensure the computer is fully shutdown to prevent any damage or risk
Gather the screwdriver
Pick closing box to safely put the screws
Using the T5 screwdriver remove all the screws
Note that there is no hidden screws
This was the hardest part for me
I used the tool opener tools from the iFixIt kit. Starting to work on the angle near the edge of the base screen and then using the spatula to work all along the base
Each SSD is located into a dedicated thermal box between the battery and the RAM
Each slot is numbered so it will help you getting them in the order you want
Use M2x4 screwdriver to unscrew the box from the motherboard
Replace/insert the SSD
Place the box again and screw it back
ある他の人がこのガイドを完成しました。
