メインコンテンツにスキップ
Dell Precision 5540 Fans Replacement
必要な工具と部品
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect your computer from all the cables.
  1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: 手順 2、 2の画像 1 Dell Precision 5540 Fans Replacement, Remove the base cover screws: 手順 2、 2の画像 2
    • Close the display lid and turn the computer over.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
  2. Dell Precision 5540 Fans Replacement, Remove the base cover: 手順 3、 2の画像 1 Dell Precision 5540 Fans Replacement, Remove the base cover: 手順 3、 2の画像 2
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    • Two case latches are approximately here.
  3. Dell Precision 5540 Fans Replacement, Remove battery plug: 手順 4、 1の画像 1
    • Here.
    • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
  4. Dell Precision 5540 Fans Replacement, Remove CPU fan: 手順 5、 1の画像 1
    • Unplug the fan cord.
    • Note the dot on the fan power socket which mark the upper side.
    • Unscrew M2 screws.
  5. Dell Precision 5540 Fans Replacement, Remove GPU fan: 手順 6、 1の画像 1
    • Unscrew M2 screws
終わりに
作成者
2人の作成者と共同で作成されました。
Nick Panin
メンバー登録日: 05/28/23
133 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 39
今までの合計 368
