メインコンテンツにスキップ
Dell Precision 5510 Keyboard Replacement
必要な工具と部品
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: 手順 1、 1の画像 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: 手順 2、 1の画像 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: 手順 3、 2の画像 1 Dell Precision 5510 Keyboard Replacement, Fans: 手順 3、 2の画像 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: 手順 4、 2の画像 1 Dell Precision 5510 Keyboard Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: 手順 5、 2の画像 1 Dell Precision 5510 Keyboard Replacement: 手順 5、 2の画像 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: 手順 6、 2の画像 1 Dell Precision 5510 Keyboard Replacement, Battery: 手順 6、 2の画像 2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: 手順 7、 2の画像 1 Dell Precision 5510 Keyboard Replacement: 手順 7、 2の画像 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: 手順 8、 2の画像 1 Dell Precision 5510 Keyboard Replacement: 手順 8、 2の画像 2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: 手順 9、 1の画像 1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: 手順 10、 1の画像 1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: 手順 11、 1の画像 1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: 手順 12、 1の画像 1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: 手順 13、 1の画像 1
    • Pull keyboard out and replace.
終わりに
作成者
3人の作成者と共同で作成されました。
Colin Hunter
メンバー登録日: 03/31/22
121 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S2G1
4 メンバー
4のガイドは作成済み
コメント 1 件
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 47
今までの合計 2,349
