必要な工具と部品
Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
Locate the data ribbon that connects the LCD panel to the mother board.
Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
Locate the black data ribbon that connects the mother board to the printing motors.
Disconnect it from the logic board, by gently pulling the wire away from the mother board.
Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
Remove the front panel.
The dell top casing should now only have two sides.
Locate the multi-colored cable that connects the power switch to the control panel motherboard.
Detach the cable, power switch is now accessible.
